    jannette92's Avatar
    jannette92 Guest
    My fridge is not working
    Sorry to hijack this post but couldn't work out how to start a new thread.
    I have read loads of good stuff on here and thanks guys it was really helpful.
    My problem is the fridge stopped getting cold - Hotpoint Iced diamond frost free. I took the advice on here and defrosted it but only waited 12hrs but it kicked off and hey presto got cold again. However it only lasted 2 days and started getting warm again. I decided to do as told on here and turned it off for 48hrs switched it back on and great it was working again. Problem is again after 2 days it has started to cool down again and looks like it is going again.
    Any more ideas is the thermostat on its way out, is it worth getting an engineer out or is it ready for the skip.
    Feb 2009
    telford
    2,090
    33
    Re: fridge problem
    Quote Originally Posted by jannette92 View Post
    its a defrost problem,with the replacement cost being in real terms cheap repairing could outway that cost.
    Jun 2007
    Cyprus
    73
    252
    Re: My fridge is not working
    Definitely a defrost problem, 95% certain to be the timer.
    Repair or replacement? It depends on age and condition of the cabinet, also whether you might have a problem getting the same size FF to fit a particular space?
    Try calling one or two local repairers. Tell them that you are quite sure you need a new defrost timer, give them the details of the cabinet, and ask them for a quote (based on timer replacement). This should help you to decide.
    Feb 2008
    adelaide sth.oz
    1,015
    either way its worth repairing,could be timer,defrost termination stat,over temp safety stat,defrost heater or a broken wire.get someone half reputable who carries stock in their vehicle but i doubt they would have a heater on board.
    good luck
    jannette92's Avatar
    jannette92 Guest
    Thanks for your posts I will contact a local engineer with your advice
    Jun 2007
    Cyprus
    73
    252
    OK good luck
    Chelsea's Avatar
    Chelsea Guest
    It sounds like deffrost problem,after you run it for 2 days,check back wall if you see ice build up,that your verification of deffrost issue,next find deff timer,should be in the bottom ofm unit by kickplate,use small flat screwdriver tu turn the dial on timer,til you hear a click,it is now in deffrost lesson for sounds of water dripps hitting a hot heater.if you hear it ,replace timer if not it could be bimetal deffrost termostat or heater.I hope this was helpful.
  1. Replies: 2
    Last Post: 08-01-2010, 11:41 AM
  2. Replies: 0
    Last Post: 11-10-2009, 02:38 PM
  3. Replies: 20
    Last Post: 14-06-2009, 05:51 PM
  4. Replies: 4
    Last Post: 15-06-2008, 09:42 AM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
