Thread: Mitsi inverter problems
14-01-2010, 06:10 PM #1
Just wondered if anyones been having problems with single phase PUHZ-RP125VKA units i.e. Inverter boards failing after install then failing again after replacement even with mods to protect against supply problems?
14-01-2010, 07:27 PM #2
Re: Mitsi inverter problems
No knowledge of any problems
90% all inverter problems at new installation are due to power supply problems.
Make sure the Neutral is 100% because any poor neutral connection at the isolator / power distribution board / main incomming board can make a 'floating Neutral'
You can measure this by measure N to Earth. Any voltage wetween N&E can be due to floating N & can make problems for any circuit boards but inverter circuit dont like this sort of power supply problem.
Testing Inverters
By fridge doctor in forum Air ConditioningReplies: 38Last Post: 15-06-2011, 06:52 AM -
Mitsi Super inverter PCB Fuses
By Latte in forum ElectricalReplies: 1Last Post: 15-05-2009, 05:28 PM -
Compatibility on Mitsi electric
By back2space in forum Air ConditioningReplies: 4Last Post: 17-04-2009, 11:02 PM -
mitsi inverter pack
By zx6rick in forum Air ConditioningReplies: 2Last Post: 20-06-2008, 06:29 PM -
Mitsi Problems
By Latte in forum Air ConditioningReplies: 9Last Post: 12-02-2005, 07:22 PM
