    Aug 2009
    St-ce
    Question The condenser is 15 metres below the compressor?
    Will I find technical documentations about making the cooling installation where, where the condenser is 15 metres below the compressor?
    How to make the return of oil on the liquid?
    What are there problems with the return of oil?
    Re: The condenser is 15 metres below the compressor?
    Whereabouts is the evaporator?
    Aug 2009
    St-ce
    The evaporator is 1 the metre over the compressor - precise air conditioner.
    Apr 2001
    79
    5,071
    35
    Oil won't be a problem as the liquid will carry it easily.
    The problem would be needing to raise the high side pressure in order to lift the liquid back up to the evaporator.
    This would be a good system to add a liquid pump.
  1. Clean Condenser Running too hot??
    By Chseybold in forum Trouble Shooting
    Last Post: 03-01-2010, 11:50 PM
  2. Energy/power saving compressor application
    By Apel in forum Technical Discussions
    Last Post: 02-07-2008, 04:30 AM
  3. compressor higher than condenser
    By agrab76 in forum Technical Discussions
    Last Post: 06-05-2008, 04:25 AM
  4. Compressor loading, cooling, and range of operation.
  5. compressor exceeding LRA
    By mush in forum Industrial Compressors
    Last Post: 09-01-2008, 05:01 AM
