16-12-2009, 10:26 AM #1
Mitsubishi Mnet transmission cable question
I would like to ask, can I use control cable -Belden 8760 to connect between outdoor unit and Mnet?
16-12-2009, 05:51 PM #2
Re: Mitsubishi Mnet transmission cable question
No
Cable size is too small at 0.8mm.
Mitsubishi specification is 2 core screen 1.25mm.
In UK this is non standard size so we use 1.5mm.
If you use smaller section cable you can get all sorts of communication problems & end up replacing it all with the correct type cable.
mitsubishi mnet city multi maintenance tool software
By skags in forum Air ConditioningReplies: 8Last Post: 10-04-2010, 04:58 PM -
City Multi Start Up Problems
By MOVHVAC in forum Air ConditioningReplies: 11Last Post: 29-01-2010, 02:38 PM -
Few question about Mitsubishi Heavy Industrial air condition
By fireduck in forum Air ConditioningReplies: 55Last Post: 12-05-2009, 02:35 PM
