Thread: nitro purgin
    Apr 2008
    north west runcorn
    28
    nitro purgin
    All the manufactors ask us to nitro purge there pipe work but none give us any flow rates for doing this?? I was told as long as you can feel the nitro comeing out the end of the pipe with the back of your hand that ok.Now that seems a bit old hat doing it like that so does anyone have more info on this ???
    Oct 2006
    1,843
    Re: nitro purgin
    Quote Originally Posted by cooltools View Post
    Uless you have a flow rate valve how would you
    measure the flow anyway.
    The acctual rate is 2 ltr a min but unless you can
    measure it that is accademic.
    So the best way is with a sensative piece of your
    skin and make sure all the pipe ends are capped with
    just a small vent hole to alow flow.
    Cheers taz.
    Nov 2009
    Western PA
    49
    Re: nitro purgin
    Taz gave as good of an explanation as I can, if not better.
    I usually hold my hose to my cheek and feel for the slight flow. Then I hook it up to the piping.
    Feb 2008
    adelaide sth.oz
    1,015
    Re: nitro purgin
    doesnt hurt to have a vertical section at the end either as you know the pipe will fill regardless of your relief hole location
    Mar 2009
    KZN, South Africa
    64
    2,212
    Re: nitro purgin
    Nitrogen...
    Nitro is an abbreviation for nitroglycrine... Won't get me going there, I promise.
    Oct 2006
    1,843
    Re: nitro purgin
    Quote Originally Posted by desA View Post
    Nitrogen...
    Anybody purging with nitroglycrine will get every one going. Away!! Fast!!
    Cheers taz
    Nov 2006
    708
    Re: nitro purgin
    You can get those vertical flow meters with a floating bobbin with adjusting screw at the bottom , they are the same type that welders use for mig and tig welding
    Apr 2008
    north west runcorn
    28
    Re: nitro purgin
    so 2ltr a min it is then boc sell a flow meter will pick one up .thanks for that taz
    Aug 2005
    5,302
    Re: nitro purgin
    Another way is to punch a hole in the rubber or plastic plugs on the tubing. This will vent enough nitrogen through the tubing to keep it clean and you don't need another regulator.
    Adi cool's Avatar
    Adi cool Guest
    Re: nitro purgin
    Just use an old service manifold. Use compound side or H.p if you like and set up using hose to pipe or component that your brazing. Set at 5 p.s.i.g ( will vary depending on pipe size) and make sure system is open e.g open service valves or remove pipe caps. Hope this helps
    Jun 2005
    Romania
    213
    Re: nitro purgin
    not how i do it, but i red it in a refrigeration book that u ad the other end to a hose and the hose you add it in a bottle of water, and theoretically if u feel once the system with nitrogen, then you just need it to bobble in the water a little bit so you make shore no air is getting back in the system
