Thread: toshiba vrv p c b problems
28-11-2009, 10:18 PM #1
Been to a toshiba MAR-F-105 HT M8-PE found it with condencer fan running in high speed. no display on p c b and no fault codes on controler. toshiba tech support sed p c b was faulty due to power supply, checked out ok.so fitted new p c b and transformer just to be safe. ran ok for one week yes you gest it the new p c b is us have checked all the bits conected to it.can you help
29-11-2009, 09:50 AM #2
Re: toshiba vrv p c b problems
check for water marks on the main PCB near the black chip in the center on the PCB, when going on defrost we had a lot of these with water entering the electrics as water was dripping on the coil (bottom left hand side) and had to re-lag the valves/pipes
Paul
"KEEP IT COOL"
toshiba sm1400 at-e
By ozzydave2006 in forum Air ConditioningReplies: 4Last Post: 09-09-2009, 11:06 AM -
toshiba accumilator problems
By sid in forum Air ConditioningReplies: 7Last Post: 04-08-2007, 12:57 AM
