03-06-2008, 05:36 AM #1
York YTK7L6F2 oil migration problem
Could this be caused by leaks on the low side? The high side is fine ,no leaks.Would adding an oil bypass line to equalize help?
Any input would be greatly appreciate by a fellow tradesman.
OAT99
13-11-2009, 03:54 PM #2
Re: York YTK7L6F2 oil migration problem
Oil migration in the machine must stop or working so, give me more information
14-11-2009, 04:13 PM #3
17-11-2009, 08:12 PM #4
please give more details of your system and compressor package.
and the used refrigerant, oilinjection tepmeratue and discharge. may be we can help.
22-11-2009, 10:05 AM #5
OAT99, The YT have a Oil eductor system. You need to check the Filter drier in Oil eductor line. With the Unit running check the Oil sump pressure, and discharge superheat. Could help you better if we could have the unit model and the running unit parameters.
Setrite
A group of Donkey's Led by a Lion can defeat a group of Lion's led by a Donkey
York DXS45 capacity slide problem
By The Screwdoctor in forum Industrial CompressorsReplies: 8Last Post: 25-05-2010, 04:40 AM -
York Screw Oil Problem
By tomt in forum Technical DiscussionsReplies: 10Last Post: 02-12-2009, 02:48 PM -
York YK Chiller Problem
By icebox in forum Refrigeration BooksReplies: 13Last Post: 01-07-2008, 06:05 PM -
Help to solve problem on York chiller
By nassersh in forum Trouble ShootingReplies: 7Last Post: 03-06-2008, 08:38 PM -
York Chiller Excessive Purges Problem
By imranmd in forum CommercialReplies: 5Last Post: 07-03-2008, 05:13 AM
