Thread: freezer room door heater
11-11-2009, 09:07 AM #1
Hello guys, have any of you changed a door frame heater on an old "storer" freezer room. If you have, how easy was it?, any likely problems to watch out for? I've got all the bits, just trying to muster up the enthusiasm to go and do any thing about it.
Andy
11-11-2009, 02:43 PM #2
Re: freezer room door heater
Sometimes it can be easy others not so
Is the trim press fitted to the door jam or screwed on?
Is the trim plastic or stainless.
It is easy enough but can be fiddly.
Some trims go all the way round some are just a feed and return, so make sure the conections are correct and then just work at it from one end and try not to tangle the heater.
Is it a flat aluminium foil type heater or the wire type?
If it is the foil type make sure the insulation is removed before you attempt to conect the last bit to the supply, other wise you will not get a good feed.
Cheers taz.
11-11-2009, 09:11 PM #3
The new heater I have got is of the flat variety, and from memory the trim is stainless and screwed on.
Andy
12-11-2009, 10:38 AM #4
if your curious have a go!!yet you can get the room makers to do this and charge it out.must say 60% most unpleasant.
cheersmmm to beer or not to beer...........lets drink breakfast
Maneurop MT51HK4A - Freezer Room
By Hatchy in forum Trouble ShootingReplies: 35Last Post: 09-08-2010, 12:10 PM -
New Freezer Room, what do you recommend?
By beachbum in forum CommercialReplies: 4Last Post: 08-10-2009, 09:18 AM -
Cold room/ Freezer combo.
By dogma in forum CommercialReplies: 14Last Post: 09-11-2008, 02:25 PM -
Misa Kit Freezer Room
By Abe in forum CommercialReplies: 2Last Post: 03-01-2007, 09:04 PM -
Freezer Room Panels
By Feeze in forum Technical DiscussionsReplies: 10Last Post: 22-04-2005, 05:58 AM
