Thread: McQuay Chiller Problem
12-09-2009, 06:54 AM #1
Newbie - 1st thread yeww. .
Having problems with McQuay Chiller ALS F 212.2 SE LN. Got 2 screw compressors - I'm trying to find the grade of oil in them - IOM Manual says to check the nameplate on the compressor but there is nothing there. I dont want to have to wait or pay for an oil sample as I need to get it running.
Daikin are being Homo's about it they said all I can do is place a Service Call because they dont have a Tech Support for McQuay Chiller... GRRRRRRR!
Anybody Help??
12-09-2009, 07:31 AM #2
Re: McQuay Chiller Problem
If the compressor's name plate is being removed some how, you need to use the chiller model number to identify the compressor's model and then the amount of oil and the grade . Usually refrigerant oils are chosen according to compressor temperature, evaporator temperature, and kind of refrigerant used.
13-09-2009, 09:54 PM #3
hi try this
http://www.mcquay.com/mcquaybiz/lite...gs/PMALS-5.pdf page 51
19-09-2009, 05:48 AM #4
Thanks goshen. Daikin finally got back to me as well.
06-11-2009, 12:58 AM #5
09-11-2009, 02:24 AM #6
Philpsy,
Details should be on tag tied to oil seperator, if not use.
Emkarate ICI RL68H.
Available from Airefrig in Australia
MQFS OZ
19-11-2009, 09:34 PM #7
Emkarate ici rl68h is the correct oil. You need about 10 lt to 15 lt max .
14-05-2010, 10:44 AM #8
please send me compressore modle nomber.then i give to proper information.i waiting for your replay.
please send me compressre modle and chiller modle nomber.
please send me which type of compressore.then i send to inforemation how much mont in fill compressure.Last edited by chillin out; 16-05-2010 at 11:59 PM.
14-05-2010, 02:52 PM #9
Mcquay Chiller problem
By hitmanzak in forum Trouble ShootingReplies: 31Last Post: 24-11-2010, 03:39 PM -
York (YK FK FL P9-CZFS CENTIFUGAL CHILLER)
By ahs in forum Trouble ShootingReplies: 8Last Post: 11-11-2009, 01:38 PM -
Problem with Trane RTAD100 chiller.
By on4hf in forum Trouble ShootingReplies: 8Last Post: 14-10-2009, 09:01 PM -
McQuay Chiller Wiring
By techni in forum Air ConditioningReplies: 7Last Post: 13-10-2009, 06:23 PM -
York YK Chiller Problem
By icebox in forum Refrigeration BooksReplies: 13Last Post: 01-07-2008, 06:05 PM
