QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > TECHNICAL REFRIGERATION > Trouble Shooting
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 07-11-2009, 01:41 AM
Niyo's Avatar
Niyo Niyo is offline
Registered User
Hey, I am new to : RE
Niyo is on a distinguished road
Unhappy Low side freezing
My main A/C system's (Marine grade, sea water condenser, 16 ton) low side from the TXV to the compressor is freezing up during the night/morning on the vessel I work in. It happens within minutes so it makes it very difficult to catch before it becomes critical. We normally run it around 240 psig high side and 53 psig low side. Once that certain time hits the high side will drop to 220 and low 38 causing it to frost over.
I just shut it down and let it sit for about 30 minutes to dethaw then turned it back on, it dropped back to the pressures at which it freezes then slowly climbed back up (I believe because of the increased heat in the vessel's air). I am still fairly new to refrigeration and troubleshooting, my senior's believe it is a faulty txv or the drier/filter. I wanted to ask any of you if there is any other possibilities before replacing the txv.
  #2
Old 07-11-2009, 02:18 AM
Gary's Avatar
Gary Gary is online now
VIP Poster
Gary will become famous soon enough
Re: Low side freezing
The pressures don't tell us anything if we don't know what refrigerant is in the system.
And the very first thing you should check is airflow.
What are the temperatures of the air entering and leaving the evap coil?
__________________
Author of TECH Method troubleshooting books
Sponsored links
  #3
Old 07-11-2009, 02:43 AM
Niyo's Avatar
Registered User
R-22 refrigerant and the air temps going into/out of the evaporator is in:72 out:64 Fahrenheit.
  #4
Old 07-11-2009, 02:45 AM
Niyo's Avatar
Registered User
Oh ya airflow is good
  #5
Old 07-11-2009, 02:50 AM
Gary's Avatar
VIP Poster
Next check the subcooling. We need to know the liquid line temp near the receiver outlet, the liquid line temp near the TXV inlet and the current high side pressure.
__________________
  #6
Old 07-11-2009, 03:12 AM
Niyo's Avatar
Registered User
txv inlet is 86 degrees, receiver outlet is 55 degrees, and high side pressure is 225 psig
  #7
Old 07-11-2009, 03:22 AM
Gary's Avatar
VIP Poster
I assume we are talking degrees F, not C?
__________________
  #8
Old 07-11-2009, 03:27 AM
Niyo's Avatar
Registered User
Yes F not C, I apologize. I am tired.
Sponsored links
  #9
Old 07-11-2009, 03:32 AM
Gary's Avatar
VIP Poster
The system has plenty of refrigerant... if anything maybe too much.
Now we need to check the superheat. We need to know the suction line temp at the TXV bulb and the current low side pressure.
__________________
  #10
Old 07-11-2009, 05:46 PM
Gary's Avatar
VIP Poster
Quote:
I would insulate that liquid line. It is picking up way too much heat along the way. This is not the cause of your problems, but insulating the line will increase efficiency.
At this point the primary suspect is plugged inlet screen on the TXV.
__________________
  #11
Old 07-11-2009, 07:44 PM
Niyo's Avatar
Registered User
thank you, alot of my responsibilities are on the job and I greatly appreciate the help/knowledge
  #12
Old 07-11-2009, 07:57 PM
Gary's Avatar
VIP Poster
I'm wondering why the receiver outlet is so cold. Is the room temp that cold? Is the condenser outlet that cold?
__________________
Sponsored links
  #13
Old 07-11-2009, 08:02 PM
Niyo's Avatar
Registered User
The vessel's house air is approx 60ish-70ish degrees Fahrenheit. We tried adjusting the thermostat up to allow the compressor some breaks in between freezes but on a vessel the crew is not to happy when they are sweating. The temp of the space that the 16ton is in is in the 80-90's.
  #14
Old 07-11-2009, 08:06 PM
Gary's Avatar
VIP Poster
What I'm wondering about is how that receiver outlet got to 55F? The only way that line temp could drop lower than its surroundings is if it is restricting. What is the liquid line temp at the condenser outlet?
__________________
  #15
Old 07-11-2009, 08:26 PM
Niyo's Avatar
Registered User
I am retarded, our accumulator is right next to the receiver, same shape and everything but condenser outlet is 78 degrees F and receiver outlet is 90 degrees F. I hit the accumulator outlet the first time
  #16
Old 07-11-2009, 09:09 PM
mad fridgie's Avatar
mad fridgie mad fridgie is online now
Veteran Poster
mad fridgie will become famous soon enough
Many boats us AEV (AXV) not TEV (TXV) can you confirm that you actually have a TEV (has a sensor bulb on the evap outlet)
Sponsored links
  #17
Old 07-11-2009, 09:12 PM
Niyo's Avatar
Registered User
yes the sensor bulb is on the evap outlet
  #18
Old 07-11-2009, 09:19 PM
Veteran Poster
Good, Do you have a control valve on the water at the condensor (small pipe form compressor or condensor is also connected)
  #19
Old 07-11-2009, 09:21 PM
Niyo's Avatar
Registered User
ya if it still works, this system is old and needs upgraded
  #20
Old 07-11-2009, 09:28 PM
Veteran Poster
From what you have indicated I would say you have a problem here.
What I want you to do is to wind in this valve (along way) this will make your head pressure rise. (if not totally goosed) If it does make a presure difference, then wind in and out, then reset.
Reduce the water pressure entering the condensor slightly.
  #21
Old 07-11-2009, 09:40 PM
Niyo's Avatar
Registered User
I will have to try that tomorrow unless I get woke up tonight over the low side freezing. I believe that valve may need some work to cooperate. Thanks.
  #22
Old 07-11-2009, 09:51 PM
Veteran Poster
If you are lucky it may just be seized.
More than likely the seat is "drawn" (lots of scratches) which is allowing to much water through. Good luck?
  #23
Old 07-11-2009, 10:46 PM
Gary's Avatar
VIP Poster
I'm still betting on the TXV inlet screen.
__________________
  #24
Old 07-11-2009, 10:52 PM
Niyo's Avatar
Registered User
Quote:
I bet your right, we are trying to get a new condenser fabricated since we cannot buy a replacement (to out of date), so when we do that we are taking out the TXV. Just trying to see if there are ways to manage this problem a little easier or else anything else we have left out of our T/S. Thanks everyone for the help.
Sponsored links
  #25
Old 08-11-2009, 12:24 AM
Magoo's Avatar
Magoo Magoo is offline
VIP Poster
Magoo is on a distinguished road
Chilled water regulation control at plant room not fine enough, check dead band control. Step unloading is not reacting quickly enough, so chilled water temp drops and suction pressure drops and you risk freezing chiller HX, being an older system the controls will have been played with by everyone twisting knobs etc., start again and re-commission system controls, double check condenser water control valves and regulators as well.
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Raising GE side by side for ventilation? sandcruiser Domestic 2 12-09-2009 07:45 PM
Quick freeze in brine solultion vs blast freezing seafood?? lhwang78 Commercial 5 25-09-2008 10:08 PM
samsung side by side sr-s2028css sork Technical Discussions 2 26-06-2008 09:06 PM
High Side Pressure is ... SULTAN Trouble Shooting 5 14-08-2007 12:53 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
