QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning > Heat Pumps
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 07-11-2009, 04:59 PM
craigix's Avatar
craigix craigix is offline
Registered User
Hey, I am new to : RE
craigix is on a distinguished road
Daikin indoor unit totally dead :(
Hello everyone, first time poster, long time reader.
Right, I've installed aircon/heat exchanger units before, some background is we live on the edge of the Pennines and don't have gas so use these to heat the house, we have one for each room.
Just installed a Daikin RYN35CVMB (indoor FTYN35CVMB) in the bedroom and it was working fine for a couple of days, went to turn it on yesterday and the indoor unit is dead. No light, nothing. Was working fine a few hours before.
Outdoor unit still has power but does nothing, changed power wire, checked connections at all ends. Changed plug fuse.
The unit was secondhand but I bought it working from an installer, it was working after I installed it. Now it just seems to be dead.
Is there a fuse on the indoor unit? What would cause even the light not to come on?
Googled all over, found many service manuals but they all rely on that light or the remote, or the outdoor unit having LEDs.
Is there a fuse in the outdoor unit?
Got a cold and angry other half and it gets COLD here in winter, I'd much appreciate any advice as it's very hard to get engineers to come out here, last time it cost Ģ150 just for him coming out, and he didn't want to do it.
  #2
Old 07-11-2009, 06:30 PM
airefresco's Avatar
airefresco airefresco is online now
Veteran Poster
airefresco is an unknown quantity at this point
Re: Daikin indoor unit totally dead :(
First check is if there is power to the indoor unit by testing across the 1 and 2 terminals. If there is power there then it is something on the indoor unit. If there is not any power there, then check the same terminals at the outdoor unit. If you have power there, then it is something on the cable between indoor and outdoor unit. Still no power there then itīs something on the outdoor unit.
On the indoor unit there is 3.15A fuse, pretty much the centre of the PCB. On the outdoor unit there are 2 fuses, but I think you will find itīs not going to be either of these. More likely the indoor board/fuse or a something on the cable.
Be careful because if you frig the board itīs going to cost you much more than 150 quid to get it fixed.
Sponsored links
  #3
Old 07-11-2009, 06:38 PM
craigix's Avatar
Registered User
There does seem to be power to the indoor unit, but it's just not coming on.
How will I go about safely taking this unit down (I'm worried about the gas), or can I get to the PCB while it's on the wall?
I've seen an unused indoor unit, this exact model, for Ģ25 not too far from here (some old unwanted unit, assume conservatory), so I'm considering just doing a straight swap. I'm guessing that's a lot easier than going down the repair route?
  #4
Old 07-11-2009, 07:16 PM
airefresco's Avatar
Veteran Poster
No not necessarily. If youīve got power to the indoor unit, then itīs probably just the fuse or possibly the board. The PCB is behind the terminals you checked for power.
Turn the power off. Check at indoor unit to make sure power is off. Take the cover off the the unit. Take the terminal block off and disconnect everything you can (remember where all the plugs go). The PCB is in the black box on the right. Youīll mess around for ages trying to get it out, but once itīs out youīll be able to see the fuse.
IF the fuse is OK, leave the PCB out, buy that other unit (assuming itīs the same model you have) and put the PCB from it in your unit. Thatīs much easier then taking the unit down and messing around with gas, etc.
  #5
Old 07-11-2009, 09:20 PM
craigix's Avatar
Registered User
Thanks for that, I got the board out, fuse ok, changed the earth (seemed slightly corroded) but still no joy.
It does just seemed to have lived that short time and died.
Any idea how expensive a brand new board might be? I'm a little wary of getting another second hand unit, unless a new board is a crazy price!
  #6
Old 07-11-2009, 11:17 PM
airefresco's Avatar
Veteran Poster
No idea our prices here are different, I would imagine that it wonīt be cheap though.
Just a thought, but are you sure the remote is OK?
  #7
Old 07-11-2009, 11:36 PM
craigix's Avatar
Registered User
Well the remote was working, and it boots up ok, I've tried a reset too. I thought using the on/off button on the actual unit would override the remote anyway.
The last time I turned it off I did use the remote, but surely the unit would not just play dead until the remote was using again? Or would it?
I'm looking at just sending the PCB off for repair now.
  #8
Old 08-11-2009, 09:32 AM
Yuri B.'s Avatar
Yuri B. Yuri B. is online now
Veteran Poster
Yuri B. is on a distinguished road
Hello!
If you
(sorry, dont know however where it is) it may also be useful to look at the power supply quality so that the new/repaired PCB would not follow the route of its predecessor.
Sponsored links
  #9
Old 08-11-2009, 09:38 AM
Yuri B.'s Avatar
Veteran Poster
I also, just in case, would test the compressor - with multimeter and then turn it on for few seconds, measuring current.
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Daikin AC parts from UK skel00 Air Conditioning 5 05-04-2009 01:24 PM
Fixing Daikin A3 Error Stuffy Air Conditioning 3 27-03-2009 07:02 AM
Daikin not working... many problems stankovicv Air Conditioning 22 23-11-2008 04:39 PM
Daikin Comp and inverter WCC73 Air Conditioning 5 08-11-2008 09:44 PM
Daikin or Mitsubishi eloroncedark Air Conditioning 25 11-08-2008 03:01 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
