QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > TECHNICAL REFRIGERATION > Refrigerants
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 27-08-2009, 11:30 PM
Silverking's Avatar
Silverking Silverking is offline
Registered User
Hey, I am new to : RE
Silverking is on a distinguished road
Question Samsung Fridge/Freezer American style
Model RS21NCSV. Had the Fridge iced up on the coil
and defrosted it manually by hot water. On two seperate occasions this has happened and on clearing up the ice the fridge has worked ok, but this time, switching on, the electronic panel is just blinking and nothing is happening. Any suggestions as it seems no one wants to touch this type of American Style fridges ?
  #2
Old 09-09-2009, 05:33 PM
sedgy's Avatar
sedgy sedgy is online now
regular poster
sedgy is on a distinguished road
Re: Samsung Fridge/Freezer American style
hi silverking,
hope the hot water was not boiling it could make the gas in the system expand to extent of making a leak depending on how much water was used,
Sponsored links
  #3
Old 31-10-2009, 11:56 PM
Refcol's Avatar
Refcol Refcol is offline
Registered User
Refcol is on a distinguished road
Hi Silverking,
Is the fan runnining in the fridge section? there is a problem with samsungs...The polystyrene ducting around the evap fan blisters out and stops the fan this is due to water/ice growing through the polystyrene. This causes an iced up coil? new ducting block or short term fix is to dry the existing one ensuring foil tape is not blocing ports and scrape away blistered polystyrene, this has worked a dozen or so times for me now
  #4
Old 31-10-2009, 11:58 PM
Refcol's Avatar
Registered User
Continued... you may have damaged the probe or thermal fuse with the water?
  #5
Old 06-11-2009, 09:01 AM
Madcap's Avatar
Madcap Madcap is offline
Registered User
Madcap is on a distinguished road
It could be your defrost heater? Although this normally trips your sockets if this happens but worth a look.
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Need help choosing an American style fridge/freezer mclovin Domestic 11 12-09-2008 01:56 AM
Lg American Style Fridge/Freezer dougdotcom Domestic 21 06-08-2008 01:59 PM
Samsung American style fridge/freezer lansburys@btint Domestic 0 26-07-2006 07:44 PM
samsung RS21 DCNS american style rbartlett Domestic 2 13-07-2006 04:07 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
