    Aug 2009
    Malaysia
    29
    CAREL equavalent of T775M2006 (Honeywell)
    Hi Guys.. I am new in this controller thingy. Anybody know what is the equavalent model from Carel for T775M2006 (Honeywell)?
    The Honeywell controller is faulty and we have plan to replace it. Trying to source for other options...
    Re: CAREL equavalent of T775M2006 (Honeywell)
    Best to ask Carel for their options, that Honeywell unit looks a bit special.
    http://customer.honeywell.com/honeyw...tSpecification
    Aug 2009
    Malaysia
    29
    ya... it looks special and complicated. Will try to contact Carel to look for equavalent function
    Split Croatia
    6,151
    Here is another company which could have what you ask for.
    Sep 2009
    NYC
    9
    could you explain what the function of the controller is for.
    as far as i con see from the manual you only have
    2 modulating outputs 2-10VDC or 4-20mA,
    no relay outputs
    2 sensor input, honeywell 1097 Ohms PTC at 77° F (25° C)
    if it is something simpel you could use the new
    johnson controls system 450 series
    Jun 2005
    Malaysia
    28
    Hello KAKA,
    i can recommend for you which Carel model for you replacement.
    can you tell me more or PM me for info.
    eg. application, no. of comp. or output.......
    i do keep stock for 1,2,4 & 5 stage controller...
    w.l.ong
  1. carel controller hidden reset button
    By 123-steve909 in forum Commercial
    Last Post: 01-06-2009, 09:54 PM
  2. Carel temperature controller issues
    By tegwin in forum Electrical
    Last Post: 30-01-2008, 03:10 PM
  3. Honeywell chilled water temperature controller
    By Cofreth in forum Technical Discussions
    Last Post: 07-09-2007, 06:32 PM
