Thread: Fujita Air Conditioner
19-10-2009, 09:57 PM #1
Hi all,
Some advice. I have a Fujita A/C which runs fine on the cooling cycle, but on heating the condenser fan starts up then the indoor fan runs for a few seconds and then cuts out. Any ideas as to the cause? The unit was recently vacuumed and recharged and the filters have all been cleaned after which it ran fine for abpout a day but it is cycling again. No signs of any leaks in the system or faults with the compressor, etc. When it was first serviced the port pressure was around 2,000 kPa but it now cuts off at just under 1,600 kPa.
Thanks for any suggestions.
21-10-2009, 01:48 AM #2
Re: Fujita Air Conditioner
indoor coil sensor?
do you have a model number and fault code and flashing light sequence?
paul H on here is very good on fuji and from your part of the worldPaul
"KEEP IT COOL"
solar air conditioner issue
By Lc_shi in forum New TechnologiesReplies: 26Last Post: 08-04-2011, 03:00 PM -
need help compatibility bi split fujitsu air conditioner
By ninox in forum Air ConditioningReplies: 0Last Post: 15-08-2009, 06:16 PM -
general air conditioner
By husnutan in forum Air ConditioningReplies: 3Last Post: 05-06-2009, 07:23 PM -
Air conditioner tripping on low oil pressure.
By g.karsandas in forum FundamentalsReplies: 21Last Post: 15-01-2009, 08:38 AM -
Dual mode Air Conditioner for RV
By tkc100 in forum TransportReplies: 13Last Post: 25-07-2007, 08:57 PM
