Thread: Vacuum time
    Oct 2005
    IRAN
    878
    Vacuum time
    Hi there,
    In EN378-2000 Part 2 is mentioned vacuum procedure according to pressure. About time it says according to the system complexity.
    Does anyone know a written standard or good practice guide which indicates the time required for vacuum?
    Even Einstein Asked Questions
    Split Croatia
    6,151
    Re: Vacuum time
    Do you mean time after system is reached desired vacuum level or total time of evacuation process?
    Oct 2005
    IRAN
    878
    Re: Vacuum time
    Hi Nike123,
    I mean total time of evacuation process.
    Split Croatia
    6,151
    Re: Vacuum time
    Quote Originally Posted by lana View Post
    Hi Nike123,
    Total time depend on vacuum pump capacity, ambient temperature, system volume and amount of moisture in system.
    That is lots of variables and it is clear that total time could not be given in meaningful manner.
    On the other hand, vacuum level is clearly indicated by pressure in system and vacuum process is easily monitored with micron gauge, and determination of its success is done by controlling pressure rise after system reached some acceptable vacuum level and vacuum pump isolation after that.
    Here is some time guide:
    Oct 2005
    IRAN
    878
    Re: Vacuum time
    Thanks Nike123,
    The link you provided is not clear. I only see this sign.
    Would you please write it.
    Thanks a lot.
    Split Croatia
    6,151
    Re: Vacuum time
    Thanks Nike123,
    Thanks a lot.
    What is your browser?
    Try use proxy server.
    Probably your ISP block some pages.
    Check this document:
    http://www.civisec.org/guides/everyones-guides
    Oct 2008
    nz
    Re: Vacuum time
    250 microns is the figure flung round the industry. Go and get yourself a micron meter. On large ac installations (VRV) I do my first vac with a 3/8 hose with the schraders removed from the system. Then break the vac with 410A then do the same process. Then on the last vac i put the schraeders in the system. This is a very effective way to get the micron reading right down where you want it.
    Oct 2005
    IRAN
    878
    Re: Vacuum time
    Thanks I got the link somehow .
    Re: Vacuum time
    Quote Originally Posted by jbomba View Post
    That seems to be going against all the rules or is it different in NZ ?
    38
    Re: Vacuum time
    Has anyone heard of treble evacuation procedures, as in breaking each stage with oxygen free dry nitrogen, Vacuum pumps flow rates are important as well. Bigger systems isolated into actual sections and dealt with individually. The final check is standing and holding vacuum rise checks plotted to determine leaks or moisture as per graph earlier posted.
    Whacking down a small volume system with a high flow vac pump can also create issues, as moisture can freeze under rapid vacuum. So sits there as a lump of ice, accurate vacuum analyses are critical. Leave all connected to system for integrity and tightness/ sealed. I personally preferr copper as opposed to flexible hoses to ensure sealed system and accuracy.
    Feb 2008
    adelaide sth.oz
    1,015
    Re: Vacuum time
    in my training days it was scavenge,evacuate,charge,run,blow off r12.scavenge,evac,charge,run,blow off.charge,scavenge,evac,charge and leave.that was a triple evacuation method by the best compressor manufacturer in the world in them days
  1. Replies: 12
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. Troubleshooting a vacuum pump and gauge set.
    By Old Codger in forum Fundamentals
    Last Post: 08-08-2008, 05:13 PM
  4. inverters pulling vacuum
    By bangoman in forum Air Conditioning
    Last Post: 05-02-2008, 09:12 PM
  5. TK basic micro-p features and functions
    By REEFER-TEK in forum Transport
    Last Post: 05-12-2007, 06:25 PM
