Thread: 404 flashing b4 TXV
08-10-2009, 04:39 AM #1
404 flashing b4 TXV
cornellius xrc1444 machine, machine has run fine for three years, low production lately, quick inspection found pressure switch at condenser was bad, (would not close swith on pressure rise and stay out), replaced, ran fine for two weeks and now customer states low production, checked condenser fan and running fine, line set very hot and no "heat" pulling through condenser. i am thinking the 404 is flashing before txv, but why and why no heat off condenser?????
thanks in advance
08-10-2009, 04:59 AM #2
Re: 404 flashing b4 TXV
sounds to me like your compressor is inefficient/damaged reeds.
08-10-2009, 07:48 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Check subcooling before TXV. If you dont have 2K or more than it is possibly flashing (2K is minimum required subcooling if you don't have liquid receiver).
Check proper fan rotation direction and RPM. Check and clean condenser.
We also need more data to be able to help you in meaningful way.
http://www.refrigeration-engineer.co...12&postcount=5
09-10-2009, 05:10 PM #4
i have no temp diff across txv's and the pressures at remote cond are 175/175. the pressures at machine are 40/180. when the machine starts freeze cycle, the pressures are 60 and 260, after 5 minutes the flashing begins ( i am assuming this is what is happening) and pressures are back to the 40/180. Could the vales be going out in this hrermetic??? would it run for a few mins and then go wacko??
09-10-2009, 05:24 PM #5
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
09-10-2009, 06:36 PM #6
no temp diff at drier, subcool is 60*.
09-10-2009, 06:41 PM #7
btw.. nike123, i do have a receiver, if that helps
09-10-2009, 08:00 PM #8
more info.....
pressures-15/125
before txv temp. 96*
after txv 77*
77*entrering plates, 57*out.
suction temp at comp. 73*
subcool is 30*, temps are raising longer machine runs. acts like it is low on charge, already 6oz. over weigh in charge.
BEKO AP930 Flashing Error/Fault Code E8 - advice needed
By tamba001 in forum Trouble ShootingReplies: 7Last Post: 02-11-2010, 09:28 PM -
Toshiba controller flashing check?!?!?!?!
By leety in forum Air ConditioningReplies: 6Last Post: 20-07-2010, 08:45 AM -
fujitsu asya09lcc lights flashing indoors
By fumagallair in forum Air ConditioningReplies: 2Last Post: 07-07-2009, 12:34 AM -
Urgent flashing indoor lights please anyone
By fridge doctor in forum Air ConditioningReplies: 11Last Post: 15-06-2009, 05:24 PM -
fuji inverter, all LEDs flashing
By paul_h in forum Air ConditioningReplies: 2Last Post: 16-11-2007, 01:15 PM
