Thread: How to check leakage?
17-02-2009, 09:26 AM #1
Leakage in inner body for chest freezer is hard to detect. any suggestion or easy way to check leakage in evaporator, accumulator or condenser?
17-02-2009, 09:29 AM #2
Re: How to check leakage?
any one want to help solve my proble?
17-02-2009, 10:09 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
17-02-2009, 07:20 PM #4
Be more patient, this is not a telephone help line forum.
The only way that I know of is to destroy the chest to gain access to the coils then pressure test with nitrogen.Brian - Newton Abbot, Devon, UK
03-06-2009, 12:53 PM #5
Recommend change new air-cond.
04-06-2009, 01:51 AM #6
seal off condensing section and pressure test it ,then pressure test evaporator section easy
22-09-2009, 08:22 AM #7
Normaly they leak in the bottom of the box due to corrosion on the pipes. Remove the bottom insulation and pressurise the unit and check. 99% of the time it is not viable to repair them. It will work out cheaper in the long run to just buy a new one.
Installation of NRVS check valves
By Josip in forum NH3Replies: 10Last Post: 02-12-2008, 01:33 PM -
compressor/evap sizing number check... and problems too !
By knighty in forum CommercialReplies: 3Last Post: 17-07-2008, 01:42 AM -
Air conditioning maintenance procedure
By Andy T in forum Air ConditioningReplies: 12Last Post: 27-05-2006, 06:57 PM -
Double check needed
By Latte in forum Trouble ShootingReplies: 14Last Post: 11-08-2004, 12:46 PM -
Compressor Check for locked rotor voltage
By shogun7 in forum Trouble ShootingReplies: 0Last Post: 04-04-2004, 12:44 AM
