18-09-2009, 04:07 PM #1
Whirlpool fridge/freezer icemaker not working
Hi guys
We have a problem with a Whirlpool stand up fridge freezer which we'd be very grateful for help with. Its a model which dispenses water and ice too.
A while ago the fridge started making a banging noise when (presumably) it was pumping in water. The noise is intermittent rather than constant. It also makes the noise when the water dispenser is being used (although not always). When its making the noise water comes out of the dispenser in bursts. Bizarrely, if you open the fridge door when dispensing water the banging stops and water flow returns to normal.
The problem has developed further now in that the ice dispsenser no longer produces ice.
Does anyone have any ideas of anything we can try? I'm not a refrigeration engineer, so any advice in layman's terms would be great!!
Thanks guys.
18-09-2009, 11:35 PM #2
Re: Whirlpool fridge/freezer icemaker not working
Likely a problem on the pcb's,usually relays problems,could you solder new relays into pcb's etc?
hers a thread that will introduce you to the likey fixes you will need an hour to wade through but the answers are in there some where.
http://www.ukwhitegoods.co.uk/module...ewtopic&t=6816
BG
19-09-2009, 11:16 AM #3
thanks for the link - sounds exactly like my problem. Much appreciated.
Whirlpool ARG 918WP (int F/F) Power on, but neither fridge or freezer working
By malwrx in forum DomesticReplies: 20Last Post: 14-06-2009, 05:51 PM -
whirlpool fridge not working rattling noise
By pops1 in forum DomesticReplies: 1Last Post: 17-02-2008, 06:52 PM -
By kottauy in forum DomesticReplies: 4Last Post: 04-10-2006, 07:56 PM -
Ice Box on my Whirlpool Fridge/Freezer not working
By Chouman in forum Trouble ShootingReplies: 5Last Post: 18-09-2006, 01:23 AM
