Threaded View
04-07-2004, 07:19 PM #2
Re: Searle cellar cooler control problem
Hi James.
RCD is not necessary but good ground is.
I would disconnect all the motors and start checking them one by one ie. if it runs and draw the right currant connect the next and so on, compressor first.
As these units should run with suction temp above 0, there must be a leak some where.
As I recall, the beer in the pubs isn't too cold.
If you are going to flush clean the system, replace the receiver if any present, thats where all the oil and dirt accumulate. That will save you running back to change oil.
POE is bad news. Make sure the unit was not operating in vacuum, if it did the oil need to be replaced. disconnect the compressor tip it over and wait till all the oil comes out. That will also give you a chance to see if it is clean or have metal particles in it.
You did not say if it is a semi or hermetic ( don't tip over semi hermetic )
My guess is that one of the motors is leaking and trips the RCD or burnt
Chemi
134A reach in cooler problem
By bvis in forum Trouble ShootingReplies: 11Last Post: 16-03-2009, 02:36 AM -
Small Searle Cooler
By Abe in forum CommercialReplies: 9Last Post: 27-01-2006, 06:07 AM -
Cellar cooler in the 'Vic
By shanes696 in forum CommercialReplies: 6Last Post: 19-12-2005, 10:43 PM -
Remote Control problem
By botrous in forum Air ConditioningReplies: 2Last Post: 12-10-2005, 05:36 PM -
IMI Marstair Cellar Cooler
By Abe in forum Trouble ShootingReplies: 25Last Post: 20-03-2004, 02:03 PM
