    annetteh's Avatar
    annetteh Guest
    Freezer not cooling, chemical smell
    Hello, I have a question about a fridge freezer. The fridge part is working fine. The freezer part is not cooling at all. When the problem first occurred, I noticed a yellow, oily liquid inside the freezer compartment, also very strong chemical smell. I have wiped up the liquid but the chemical smell is still very strong. It seems that the freezer was defrosted just before it stopped working, but not by me, so I can't say much about that. Please can someone tell me what the problem might be?
    Oct 2008
    mallorca, spain,
    75
    768
    Re: Freezer not cooling, chemical smell
    it sounds like you have two systems a fridge and a freezer, also you seam to have had a knife welding<mother < or< other < prising the frost off the freezer box= result lost gas out of the freezer, you need a domestic fridge man , do let us know how you went on
    Jan 2008
    qatar
    52
    61
    it mean evaporator broken by you or someone. check properly there is gas leak or not.
    TRY TO LEARN MORE ABOUT A/C SYSTEM
    May 2008
    66
    802
    stop the system and perform a leaktest,soap and water will do just fine.
    Ice
    Oct 2008
    mallorca, spain,
    75
    768
    how to test brocken evaporator?=as per letter 2
  1. Zanussi zen2925 fridge freezer not cooling
    By fusion007 in forum Domestic
    Last Post: 19-07-2009, 03:52 PM
  2. Replies: 3
    Last Post: 28-04-2009, 06:06 PM
  3. Blast Freezer Cooling / Heating Times
    By selbstar81 in forum Technical Speculations
    Last Post: 16-08-2008, 06:50 PM
  4. Compressor loading, cooling, and range of operation.
  5. fridge freezer cooling fan
    By bazza in forum Trouble Shooting
    Last Post: 28-02-2007, 11:33 PM
