Thread: Replacement for R403b
28-07-2009, 04:10 PM #1
Hi Folks
I maintain some Thermo King refrigeration units which Use R403b refrigerant. This is a blend containing R22 and was a drop in replacement for R502 (r.i.p)
Presumably then this will not be available past the end of this year. Can any one therefore suggest a replacement that does not require changing from mineral oil to POE?
Any help or your experiences will be most gratefully received.
Am I also right in thinking that I will not be able to use any virgin R403b after the end of the year.
30-07-2009, 07:56 AM #2
Re: Replacement for R403b
Iwork TK unit SDII MAX,and I replace R403b with R404a and change oil.Other solution I dont know
20-08-2009, 03:36 PM #3
You are right that virgin R403B will not be available from the end of the year as it is a HCFC.
You have several options if you want to stay on mineral oil: R422A (Isceon 79) or R428A (RS52) are probably the best options.
Both are compatible with mineral oil and both suitable replacements for low temperature refrigeration. Capacity-wise, R428A has slightly better capacity than R422A and looking at my tables, should match R403B closely at -30 C. It also has negligible glide (0.5 C) which always helps!
Pressures are similar to R403B (slightly lower)
R22 replacement
By brad__34 in forum RefrigerantsReplies: 28Last Post: 04-06-2010, 09:06 PM -
Replacement Chiller Barrel Selection
By archibaldtuttle in forum Air ConditioningReplies: 0Last Post: 09-06-2009, 08:09 PM -
Ranco K14 replacement
By sturgm in forum Technical DiscussionsReplies: 3Last Post: 30-08-2008, 06:09 PM -
Replacement Screw Compressors
By dkemper in forum Technical DiscussionsReplies: 2Last Post: 13-10-2007, 07:22 PM -
F 11 replacement for flushing
By andrewuk in forum RefrigerantsReplies: 1Last Post: 17-10-2003, 11:03 PM
