Results 1 to 13 of 13
Thread: What is CFM?
05-08-2009, 12:58 AM #1
Re: What is CFM?
Originally Posted by kamal12341
Not always. You cannot use examples like this for all applications. What works for air conditioning systems will not apply to refrigeration systems.
05-08-2009, 01:01 AM #2
Re: What is CFM?
Some evaporators may also have different fan blade pitches for the same diameter. Or, they might be listed as different airflow due to higher static pressures, which will cause a change in the delivered airflow volume.
