02-07-2009, 10:43 AM #1
beko cda543f frost free ff. Freezer does not freeze!
Hi I have had the above model for typically just over a year, when all of a sudden the freezer started playing up, things were not freezing, like ice cream being all melted etc. As i said, typically the warranty has expired by a week or so. The dial inside the fridge i presume is used to control the temperature and was always fine set between 2-3 ( the scale from 1 - 5 ) The fridge has remained fine.
So I tried moving the scale to 4 to see if this would work but only results in the fridge becoming too cold and semi-freezing salad etc! Can anyone help?
03-07-2009, 09:42 PM #2
Re: beko cda543f frost free ff. Freezer does not freeze!
look in the back of the freezer, check to see if there is an ice build up behind the rear panel, if there is then you have a defrost problem which prevents air circulation
02-08-2009, 09:06 AM #3
I have the same problem, there is a build up of ice at back of freezer, icould anyone tell me if there is any way of fixing this myself
02-08-2009, 10:35 AM #4
Turn fridge freezer off for 48 hours to fully defrost internally then switch back on and test working ok. You pay for what you get beko cr&p.
Transvestites are men who like to eat, drink, and be Mary.
Frigidaire FRC150 FF - fridge not very cold freezer forming frost!!
By TriciaA in forum Trouble ShootingReplies: 3Last Post: 04-08-2009, 04:24 PM -
Beko Frost Free Fridge Freezer failing to cool
By Derek Max in forum Trouble ShootingReplies: 1Last Post: 19-06-2009, 07:31 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
Zanussi Frost Free Fridge Freezer
By john123 in forum DomesticReplies: 2Last Post: 31-12-2007, 06:53 AM -
Beko frost free freezer/fridge help needed
By DJT in forum Trouble ShootingReplies: 14Last Post: 22-12-2007, 12:13 AM
