Thread: Faster Cooling
30-07-2009, 12:38 AM #1
Faster Cooling
If an evaporator has more CFM, does it mean that it is going to cool faster compared with another evaporator of the same characteristics with less CFM??
30-07-2009, 02:06 AM #2
Re: Faster Cooling
more CFM means more efficiency??
30-07-2009, 03:41 AM #3
Re: Faster Cooling
Depending on which type of cabinet the evap. fan is installed. In an open showcase, cfm is less so that cold will not be wasted throwing it outside the unit. In an enclosed type like cold boxes, it need a strong fan so that air will forced to moved around the close space especially in freezer where cold air is dense....
getzzz.....
Energy saving Glycol filled dry cooler circuits
By Jasper in forum Technical DiscussionsReplies: 14Last Post: 19-06-2008, 02:18 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM
