Results 1 to 29 of 29
Thread: i am looking for a tool..
19-05-2004, 08:49 AM #1
I am a young engineer - who is writting her graduate work for the technical university
- and in my work i need to do some calculations (i need to pick up some air conditioning device for an apartment).
Is there any tool which would be helpful for this request..
I am not asking about air conditioning selection programs provided by specific companies
Btw - I am new to this portal - so if there is any info here about it - forgive me
GreetingsLast edited by halwaya; 19-05-2004 at 09:01 AM.
19-05-2004, 09:48 AM #2
Re: i am looking for a tool..
Can you be more specific about what you need?
________
Suzuki TSXLast edited by Argus; 07-02-2011 at 08:04 AM.
19-05-2004, 10:38 AM #3
During my univ curse I had no classes on Air Conditioning,
so I am more like a blind child in a fog. Studying on my own.
Fist of all i need to find an air conditioning device who provides thermal comfort in the apartments (during summer and winter). The device should be installed in an existing flat.
I know the max outside temp., humidity of the air, the heat of the insolation... the cubature of the flat etc. etc. Is there anything else I should know?
Thermal Comfort in the flats is :
-temperature: 22 - 26 C deg
-humidity: 30 - 65 %
-velocity of the air: 0,05 - 0,3 m/s (according to the value of the temp.)Last edited by halwaya; 19-05-2004 at 10:46 AM.
19-05-2004, 11:46 AM #4
Like Argus, I don't understand what you need specifically.
Do you need AC units, documentation, leaflets, selection help, standards...
Conditions in the flat are.....or should be...
Splits (wall, ceiling, ground..), watercoils, how many flats, outside conditions, which gas, tubing (copper, ABS..)
It's not that simple as it seems sometimes.
19-05-2004, 01:51 PM #5
I think the young lady may mean, that she has to calculate the heat load on the said apartment and then design an airconditioning device to cool it
"The old codger"
19-05-2004, 02:07 PM #6
Yes.. i need some selection help.. AC units too
Sadly i need to deal with something unknown to me..
so even asking question is a problem
My professor asked me to pick up some flat - and select an AC device for it. What data do I need so i can make this work done? What shall i calculate?
I was wondering if there is any online help for such requests...:: without women hell wouldn't be hell ::..
19-05-2004, 03:05 PM #7
hi halwaya,
have you noticed how quick all the gentelmen jumped for your help?
I never heard of such a learning methode and I frankly think that your proffesor HAVE to give you better and more specific instrutions.
there are many good and very educated people here and even if they will give you the software to calculate the heatload in your appartment,m I dont think you will know how to use it or understand what parameter to fill in.
i would suggest you to explain EXACTLY what you need and I'm sure that in no time, someone will do it for you.
as I said before, ALL of us are gentelmen.
have a lovely day
chemi
19-05-2004, 04:26 PM #8
I really do appriciate all the posts,
and I agree you're gentelmen
(However i do feel like a blonde )
You are right chemi-cool - my knowledge on
air conditioning is rather basic. So far i was
into heat exchangers in some instalations,
and into gas purify devices.
I can complain about our education system
(as i had almost all engineer subjects
including electronic & automathic through civil engineering,
microbiology, ecology, law and economics
- these last 2 are useful anyway).
Once again I appriciate your kindness and your will of helping me.
Thank you..:: without women hell wouldn't be hell ::..
19-05-2004, 08:16 PM #9
you need to speak to our new guy piotr -who's from poland and has a degree in hvac
cheers
richard
19-05-2004, 08:24 PM #10
try this link to a free trial program - I'm sure that you can design your cooling load and print the results within the free trial period.
http://www.im-looking-for.com/air_co...lculations.htm
Once you have the room load it will be easy to select the correct equipment from manufacturers sites
Frank
19-05-2004, 09:09 PM #11
Originally Posted by rbartlett
19-05-2004, 09:27 PM #12
[QUOTE=halwaya]is piotr his nickname? i did a member search, but no results :/
no that's his name !
although it may be spelt poitr.....he has only just joined us and i spent the day in sunny london with him..good guy
he has moved down from london to some place near the office whilst he settles in..so i don't know if he's on the net yet..
cheers
richard
19-05-2004, 09:53 PM #13
OK then kind man
please ask him to contact me
would be easier this way.
greetings to you and Piotr..:: without women hell wouldn't be hell ::..
22-05-2004, 02:20 AM #14
This link maybe of some help it provids heat load calcs for various types of AC units
http://www.voltasac.com/split_ac_home.htm
24-05-2004, 08:00 AM #15
My professor gave me more data after our last consultation.
Outside:
- temperature: 30 C deg
- humidity: 40 %
- pressure 1000 hPa
Inside:
- temperature: 20 C deg
- humidity: 40 % (=const)
- cubature of the room is : V=4 x 5 x 2,5 = 50 m^3
- in the room we have 2 people
My AC device should work in a closed cycle, so it uses inside air to cool it..
Sadly i need to do all the calculations on my own - using some formulas to calculate the heat load
(so for now i will spend more time in a library)
Later i need to pick up some existing AC device so it works there in this room.
Wish me a good luck.Last edited by halwaya; 24-05-2004 at 08:07 AM.
24-05-2004, 10:10 AM #16
hi halwaya,
here are a few links that can help:
http://www.ba.ars.usda.gov/hb66/012heat.pdf
http://www.heatload.com/unico/heatloadpreform.htm
http://www.xpedio.carrier.com/idc/gr...it/570-878.pdf
http://www.hvac.cc/
the last one has a free trial, download it and you can do your calculations .
good luck on your project
chemi
25-05-2004, 06:15 AM #17
Originally Posted by halwaya
You will also need the type and thickness of wall material to look up factors and calculate transmission cooling load for the walls. This will be different for windows, of course.
Also, if this is a real application, you had better be sure there is no substantial sun load, such as exposed, south or west-facing walls & windows, for example, or an uninsulated roof.
Good luck,
RogLast edited by RogGoetsch; 25-05-2004 at 06:18 AM.
25-05-2004, 07:04 AM #18
hey Rog,
Thanks for your sugestions. I will have to calculate that too plus the heat loads from the lighting system.
I've already found out that there is a lot of fun with these calculations.
Luckly it is not a real application - my professor wants me to learn how to do it
Greetings..:: without women hell wouldn't be hell ::..
25-05-2004, 09:19 AM #19
Yo,
you might also consider other internal loads as computers, printers, coffee machines, etc. if you really want to get a "super" accurate calculation !
Bye,
Niko
15-06-2004, 02:54 PM #20
hehe.. i thought this would be some easy job to do
but anyway
my callculations are done,
my work aprooved
thanks for all who helped me
greetings..:: without women hell wouldn't be hell ::..
24-06-2004, 11:52 AM #21
From Now I Have The Master Engineer Degree
24-06-2004, 05:06 PM #22
CONGRATULATIONS.
From all of us. Go get them girl!!
Chemi
28-06-2004, 04:15 PM #23
Hi!
Take a look for CoolPack, from DTU. A "swiss army knife" of refrigeration tools. Free, downloadable from the net.
Best regards,
-Manuel.--------------
Manuel Camacho
Dartford, England
06-07-2004, 09:43 AM #24
06-07-2004, 05:32 PM #25
Love your Polish
Chemi
26-01-2006, 01:17 PM #26
125W/m2 in living areas
and 80W/m2 in bedrooms
29-03-2006, 04:47 PM #27
Hi guys
My question is on what basis the receiver-dryer, TEV, and accumlator can be selected for the AC unit.
my regards
30-03-2006, 08:44 PM #28
Originally Posted by mohamed khamis
Where in Malaysia are you ?
Richard
01-04-2006, 08:05 AM #29
Thank u so much for ur concern... I am in Johor Bahrau... all i need to learn how to select the TXV, and other components in the AC system such as receiver-dryer, accumulator that mean i am looking for the basic fundemental for selecting theses components and once again i apreciate ur kindness
regards
Mitsubishi M-Net maintenance tool for sale?
By sigorst in forum Air ConditioningReplies: 6Last Post: 14-12-2009, 08:40 PM -
Service Checker Tool
By KISS KISS BANG in forum New to REReplies: 3Last Post: 04-05-2009, 10:53 PM -
simulation tool
By Lc_shi in forum FundamentalsReplies: 7Last Post: 23-02-2006, 02:46 AM -
want good price r410 flaring tool in aust ?
By peter1927 in forum Tools and CalculatorsReplies: 2Last Post: 24-11-2005, 05:48 AM -
Looking for a Good CRM or Database Tool for marketing any help
By PAXFREON in forum Legal-Business-MarketingReplies: 2Last Post: 12-03-2004, 04:53 PM
