    Kuwait
    Sabroe compressor
    I would need to share experience of any colleague dealing with this compresor before, my client has one sabroe condensing unit of twin compressor , recipocrating low temperature of 66kw, each,my client need to seprate both compressor, and use one of them for seprate blast freezer room,and he wanted to use it with one existing evaporator, who have experience of this kindly tip me, I also noticed that the sabroe compressor is being used R-22, but when checked sabroe compressor website , I got R-134,502,717 and 404 only, it is clue for me, I need your exprience friends and advice, if the operation will be possible or not and how would I do that?
    many thanks
    May 2006
    India
    399
    Re: Sabroe compressor
    Yes , you can use a single compressor but the evaporator will not match the capacity ; hence need to decide what capacity required from the evap .
    NEED MORE INFO ABOUT THE LOAD ETC. BESIDES, THE OLD COMP MAY NOT BE COMPATIBLE WITH NEW REFRIGERANTS ; HENCE CHECK WITH SABROE.
  1. MP66 & Compressor Overheating
    By Intermez in forum Technical Discussions
    Last Post: 13-04-2010, 08:58 PM
  2. replacing R12 comp with POE compressor
    By Richvacr in forum Commercial
    Last Post: 02-05-2009, 07:04 AM
  3. seized inv compressor
    By flash in forum Air Conditioning
    Last Post: 09-04-2008, 06:56 PM
  4. Compressor Capacity
    By engrkate in forum Fundamentals
    Last Post: 13-10-2006, 12:11 AM
  5. screw compressor
    By vinod in forum Trouble Shooting
    Last Post: 17-12-2005, 01:46 AM
