    Feb 2008
    ireland
    42
    ice cream machine
    looking at an ice cream machine it had a new compressor fitted to it by another engineer but he never finished it. So i changed the drier, vacuumed and topped up with gas. The system was r12 but the new comp was r134a. I've used r409 gas.Now when ever its turned on there is no heat in the liquid line plus the discharge is'nt as warm as it should be, but the suction is freezing. It pulls the first few ice cream ok but is taking to long to prime after.Then when it is turned off the suction line loses it's freeze stright away then there is like a whistle sound like gas leaving the chamber. any thoughts??
    ps mod's i put this in domestic by mistake sorry
    Apr 2001
    79
    5,071
    35
    Re: ice cream machine
    We can't see it from here and you have provided almost zero information.
    TXV or cap tube?... temperatures?... pressures?
    At this point if I had to take a wild guess I would say it is probably overcharged, but that's just a guess.
    Quote Originally Posted by lesbattersby View Post
    Thanks for notice, other posts deleted now.
    lebanon
    130
    hi
    metering device expansion or cap are too much different the orifice in f 12 too much wider then 134 so thats why ur suction freezes quick
    u have to check expansion device&start from from here
    check compressor capacity & make a good selectionfor ur tev
  1. Carpigiani ice cream machine charging
    By mr whippy in forum Technical Discussions
    Last Post: 31-01-2009, 02:30 PM
  2. ice cream machine
    By jnyao in forum Commercial
    Last Post: 08-07-2007, 09:15 PM
  3. Elderly Ice cream machine.
    By Onthecut in forum Trouble Shooting
    Last Post: 20-11-2005, 11:31 AM
  4. Cattabriga Ice Cream Machine
    By Abe in forum Trouble Shooting
    Last Post: 26-04-2003, 01:06 PM
