Thread: Toshiba Interactive Intelligance
27-03-2004, 10:03 PM #1
outdoor high pressure switch fault ,this is fault shown on the PC , VRV with 4 ceiling mounted units connected 3 pipe heating ,cooling .Cleaned filters on ceiling units ,switched VRV off then on problem clears for a day or so then returns...............have investigated found marshalling boxes with soliniod valves openning and closing action.................anybody got any ideas
28-03-2004, 09:21 PM #2
Re: Toshiba Interactive Intelligance
Frank
On Toshiba VRF you will get a fault code on the controller if you have a high pressure fault. What code are you getting?
29-03-2004, 07:11 PM #3
Hi Frank, PC software it shows 33,if i take the cover off the VRV is there a digital display there Frank ? i`ll have a look to-morrow
30-03-2004, 02:00 PM #4
not familiar with Toshiba VRF personally,
but what i think frank is refering too was the wall mounted controller did it show this error code as well? (Like Daikin's do, if your familiar to them?). Or is it not an display type?"Old fridgies never die, they just run out of gas!"
30-03-2004, 03:40 PM #5
What do Tosh say about it?
They used to have a decent technical section to help with this sort of thing.
________
GXLast edited by Argus; 07-02-2011 at 08:02 AM.
30-03-2004, 06:49 PM #6
Hi guys, it`s a BMS controlled system windows 98 running interactive intelligence software ,the fault code 33 is shown on the PC ,have not approached Tosh as yet .
11-05-2004, 10:30 PM #7
On Tosh 3 pipes you can usually get a fault code from any of the PCBs in the outdoor unit (set rotary switches to 2 and 0 also take some paqper to shield the LEDs from sunlight), the Multicontroller and the indoor unit as well as the remote.
Toshiba have a good technical department alternatively you could try HRP!
12-05-2004, 06:36 PM #8
Thanks for that ,i`ll give it a go
Frank Mc Bride.
Toshiba Digital Inverter range?
By Slim R410a in forum Air ConditioningReplies: 19Last Post: 18-10-2010, 02:45 PM -
Toshiba Warranty
By gwilliamson in forum Air ConditioningReplies: 1Last Post: 17-05-2006, 05:59 PM -
Looking for air temp sensors for Toshiba GR334 fridge (have part number)
By Cluster in forum DomesticReplies: 1Last Post: 19-02-2006, 12:08 AM -
Toshiba A/C Compressor size
By Chris2005 in forum Air ConditioningReplies: 9Last Post: 10-04-2005, 09:21 PM
