    May 2009
    Bulgaria
    59
    5
    Installation question split system
    I am building a house, and the time has come to drill a hole in the wall for the pipe between the outdoor unit and the indoor unit.
    I was told by an installer that the location of the hole depends on which brand of a/c we choose. He said that the pipe connects to the right hand side of the Midea indoor unit, but to the left side on Samsung.
    Is this correct? I would have though that it would have been possible to configure the indoor unit so that the pipe can connect either on the right or on the left, isnt the internal connection reversible?
    On both ends of the box there seems to be a plastic bit which can be snapped out, (for the pipe).
    Split Croatia
    6,151
    Re: Installation question split system
    If you are not pre-installing pipes, than it doesn't matter. Most of units has pipes coming from unit at right side (when you look in front of unit). Best is to drill hole at left side. In that way connection is accessible and doesn't end in middle of wall.
    Check this forum for Samsung option code posts.
    May 2009
    Bulgaria
    59
    5
    Surely if the pipes are connected on the right side, the hole should be on the right side too (otherwise the pipe has to wrap around the indoor unit)?
    The Samsung pipes connect on the left by default apparently. I'd like to know if it is possible to change this by reversing the connection inside the indoor unit.
    ireland
    1,451
    pipes can be bent to fit right or left side, they are not reversable per se.
    al
    May 2009
    Bulgaria
    59
    5
    Do you mean bent in a U shape in the casing?
    ireland
    1,451
    pipes exit the evaporator and are bent in along the casing, these pipes can be bent the opposite direction if required. usually i install so the pipes are jointed in the casing, not outside unless trunking is used, this keeps all pipe work hidden.
    al
    Jan 2009
    United Kingdom
    242
    Quote Originally Posted by jom2000 View Post
    If you know what system(indoor unit) your installer is supplying, can't they either provide a template or have the indoor unit on site so you can use the back plate?
  1. Restricted split system license Australia
    By mak74 in forum Training
    Last Post: 05-04-2011, 06:26 AM
  2. System Burn Out Troubleshooting
  3. steps on tonnage calc for split system
    By Jimmy.Thurman in forum Fundamentals
    Last Post: 05-05-2009, 11:27 PM
  4. Lost Remote Control for Split System AC
    By kiamaian in forum Air Conditioning
    Last Post: 12-04-2009, 06:12 PM
  5. Replies: 8
    Last Post: 20-05-2006, 04:21 PM
