    Feb 2009
    49
    water pressure tool [chillers]
    Can anybody help i am after a water pressure gauge to carry with me to make sure i have correct pressure when on site as some sites i have come across have none fitted. cheers.
    Re: water pressure tool [chillers]
    If you are looking for differential measurement across the chiller or commissioning valves then check out these people, they've been doing it for years and years.
    http://www.poddymeter.co.uk/
    Split Croatia
    6,151
    Quote Originally Posted by johnny cool View Post
    For chillers, correct pressure is not that important, regular analog water pressure gauge with 0,1 bar resolution and class 2 accuracy is good enough.
    Important is correct flow, which need flow measuring instrument. Best is to use one of major flow regulation valve manufacturers (Danfoss, Herz etc...) because you usually deal with them, and if you measure their flow you don't need to calculate anything since everything is stored in their memory.
    ireland
    1,453
    sounds like you need a binder gauge, one that you stab in to check differential pressure across the coil?
    al
  1. Superheat and Subcooling
  2. cold river water
    By eftimios in forum Fundamentals
    Last Post: 09-11-2008, 06:37 PM
  3. PT chart for different elevations
    By dkalasz in forum Tools and Calculators
    Last Post: 20-07-2008, 05:09 PM
  4. Water Chiller Gas Pressure ??
    By rajpatel in forum Commercial
    Last Post: 14-05-2008, 12:41 AM
  5. Psychrometrics
    By Prof Sporlan in forum Fundamentals
    Last Post: 01-12-2001, 06:48 PM
