Thread: Accumulator
    Mar 2005
    Nearby
    22
    Accumulator
    Hi every body
    In a secondary coolant system we have screw type compressors (HSN 7471-75-40P and CSH 8571-140-40P)and wondering if we need accumulator or not .
    On the other word , is liquid return to screw compressors a serious problem ?
    Thank u for ur attention.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Accumulator
    That is not the right question.
    The question you shall ask to yourself is: "did I make all efforts to avoid liquid floodback?". If not or unsure, install an accumulator.
    Mar 2005
    Nearby
    22
    Re: Accumulator
    We r gonne install but not sure if it is possible to omit it or not ?
    Is liquid flood back a threat to screw type compressors or these types can bear in case of a little amount of flood back
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Accumulator
    Floodback cannot be considered at design time. Not an option.
    Then, the compressor may bear it or not, it doesn't matter.
    Valrico, Florida
    509
    Re: Accumulator
    I would tend to go for the safest approach and install a accumulator.
    May 2008
    66
    802
    Re: Accumulator
    by the way, liquid flood back is hazardus for EVERY type of compressor. the scroll can take and cope better whit flood back,all the others crash and dye.
    ice
    Mar 2002
    Tehran
    55
    38
    Re: Accumulator
    I think it depends on ur cycle and exp.v type, but Im also not sure about necessity of liquid-return protection for screw compressor. if anyone has such exprience I`ll be appriciated to get advises.
    S.P
  1. AWHP design - suction accumulator
    By desA in forum Heat Pumps
    Last Post: 05-09-2010, 07:53 AM
  2. Replies: 8
    Last Post: 08-03-2009, 03:12 PM
  3. Thermo KIng CB Max suction accumulator tank cleanning
    By coldkeeper1 in forum Transport
    Last Post: 02-05-2008, 05:40 AM
  4. suction accumulator control
    By samiam in forum Fundamentals
    Last Post: 22-06-2007, 05:49 PM
  5. accumulator
    By mohamed khamis in forum Fundamentals
    Last Post: 12-05-2006, 10:00 PM
