Thread: Designing a refrigerator
03-04-2009, 11:52 AM #1
I am designing a refrigerator and i figured out where all the components are going to fit where. I got a 1/2HP compressor set and it runs on 404a.
How can i determine how much refrigerant I will need to properly run this custom made system.
Any help would be apprecaited.
03-04-2009, 12:05 PM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Designing a refrigerator
By trial and error, if capillary expansion device, and by subcooling and superheat, if TXV!
08-04-2009, 07:47 AM #3
Dear,
Let me know the spec. of your eva+cond, then i can tell you approx. how much gas will be required.
Or let me know you ref(F/R) voulme then i can tell you approx.
Designing Roll Bond Evaporator
By Munzar Ata in forum FundamentalsReplies: 11Last Post: 05-08-2010, 11:31 AM -
very big problem with refrigerator comp.heat up low cooling in REF portion
By jahangir.ahmad in forum Air ConditioningReplies: 6Last Post: 11-07-2008, 03:07 PM -
pressure release duration in refrigerator
By junhonguk in forum Technical SpeculationsReplies: 14Last Post: 13-01-2008, 07:06 PM -
Propane Refrigerator Conversion
By zolar1 in forum RefrigerantsReplies: 26Last Post: 04-02-2007, 03:42 AM -
How the refrigerator is less humid than outside
By Abu Bakar in forum FundamentalsReplies: 0Last Post: 19-06-2003, 03:06 AM
