Results 1 to 12 of 12
09-02-2009, 04:49 PM #1
How do you determine type of refrigerant in the system?
Does anyone know how you are able to determine the type of refrigerant that is already inside the system? Sometimes the type of refrigerant that is actually inside the system is not the actual type that is specified on the unit's tag. Is there any way to tell what has actually been used in the system?
Any advice is appreciated. Thanks.
09-02-2009, 05:36 PM #2
Re: How do you determine type of refrigerant in the system?
Try taking the standing pressure of the refrigerant in the system & ambient temperature.
Look on a refrigerant comparitor to see which refrigerant has pressure which is a match for the temp.
Provided the system still has some liquid refrigerant this basic test should give first indication.
09-02-2009, 06:35 PM #3
look on TEV if fitted ,look at compressor lable for ref type or drier ,if its worth it get a sample analized
09-02-2009, 07:05 PM #4
09-02-2009, 07:08 PM #5
i have not I take the hint
09-02-2009, 07:13 PM #6
The only way to be sure is to get the refrigerant analysed or use a refractometer.
09-02-2009, 07:16 PM #7
09-02-2009, 07:18 PM #8
09-02-2009, 07:35 PM #9
words eaten or something like that ,oil and what has been
09-02-2009, 09:50 PM #10
Just check all the empty cylinders that will be dumped in the plantroom.
taz.
10-02-2009, 07:20 AM #11
12-02-2009, 09:06 AM #12
Hi! I know of an analyser under the barndname TASCO which is designed to determine the refrigerant compositions. The machine can even identify most HFC and even CFCs.
Hope it helps!
Koh - S'pore
Refrigerant recovery system
By Dns in forum RefrigerantsReplies: 3Last Post: 15-04-2010, 02:38 PM -
Calorex Pool Heater
By airefresco in forum Heat PumpsReplies: 22Last Post: 06-02-2009, 09:03 AM -
automating a chilled brine refrigeration system using ammonia refrigerant
By luciom in forum IndustrialReplies: 29Last Post: 02-10-2008, 09:48 PM -
How an expansion tank works?
By Raadster in forum FundamentalsReplies: 6Last Post: 25-07-2008, 02:25 PM -
inverters pulling vacuum
By bangoman in forum Air ConditioningReplies: 2Last Post: 05-02-2008, 09:12 PM
