Thread: trane chiller controller
13-01-2009, 08:38 PM #1
Hello guys does any body have any info on how to set it up, its a recipe chiller 100hp compressor and its about 15 years old and the controller has a picture of compressor on it and as it loads up and down the lights come on and off ,any info will be helpful.Thank you
13-01-2009, 10:57 PM #2
Re: trane chiller controller
A model number might aid the question a little
15-01-2009, 08:20 AM #3
hello, is that a trane cga series chiller with a rcm module controlling it? with a board that controls condensor fans to the left of the main board. is there a dial on the bottom left of the main board?
15-01-2009, 07:40 PM #4
Ghaz.
I have some Trane controller details.
But I am not sure as to whether they are what you are after.
Is there any way you could elaborate?
You are welcome to what I have got!
Grizly
15-01-2009, 10:41 PM #5
The controller has a switch to the bottom right, which you would slide over to the pgm mode, then use the four dip switches to change the various settings, which are binary settings, i'll look for the relevant info and send it to you. The settings are for number of compressors, stages temps etc, too many to remember. If the controller doesnt hold the memory when the power is switched off, then you will have to reset these every time. If i can figure out how to post a jpg picture here, then i will
16-01-2009, 03:58 PM #6
I've added the link to the last message, hope it is of use.
Andy C.
Trane chiller
By Lman in forum Trouble ShootingReplies: 4Last Post: 13-11-2009, 03:51 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM -
York & Trane Reciprocating Chiller
By Gigas in forum Air ConditioningReplies: 3Last Post: 21-05-2008, 12:21 AM -
Trane Chiller low temperature operation
By Brads in forum IndustrialReplies: 2Last Post: 20-01-2008, 07:18 AM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM
