Results 1 to 10 of 10
Thread: Nitrogen
01-01-2009, 12:24 PM #1
Nitrogen
In which cases can nitrogen be dangerous ?
01-01-2009, 12:37 PM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
01-01-2009, 12:39 PM #3
Re: Nitrogen
How long is a bit of string?
You ask a very open ended question!!
Nitrogen in itself is harmless, we are surrounded by it.
We breath it in at 80% of the total make up of air.
It only becomes a problem when you miss use it when it is under pressure. Pressure kills.
Nitrogen is very safe, but do not leave any in your system after pressure testing because it is a non-condensible.
taz
01-01-2009, 01:06 PM #4
Re: Nitrogen
Sorry Taz.
I meant nitrogen in cylinder for refrigeration work purposes.
I would like to know how safe are the kits sold.
I write about electronics and refrigeration service and I am very worried about safety.
Moises
01-01-2009, 01:09 PM #5
Re: Nitrogen
It can also be dangerous if it displaces the normal room air.
For example a Liquid Nitrogen freezing tunnel may require a O2 measuring device in case spillover into the room lowers the available oxygen.
01-01-2009, 01:50 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
01-01-2009, 01:57 PM #7
Re: Nitrogen
Thanks for mentioning asphyxiation risk.
I found an nitrogen accident report, but I can not post links yet because I am a new member:
archive.org/details/gov.csb.2006.hazards
02-01-2009, 03:46 AM #8
14-01-2009, 04:48 AM #9
Re: Nitrogen
As far as I know the standard pressure in a standard
88 cuft cylinder is @ approximately 2214 PSIG, if the end were broken of from a fall, say off 2 story roof, then there is a good possibility that the nitro cylinder could turn into a rocket and end up being a short lived and very deadly health hazard.
Personally I never stand up my nitrogen in the field, unless I can tie it up to something sturdy, but I'm lazy so I just lay it down for safety.
15-01-2009, 09:22 AM #10
brazing under nitrogen
By cool#9 in forum Air ConditioningReplies: 5Last Post: 24-10-2010, 08:30 AM -
Nitrogen Condensing by Temperarture
By Reflexive in forum Technical DiscussionsReplies: 0Last Post: 21-12-2008, 12:23 AM -
Soldering with/without nitrogen?
By mooka in forum DomesticReplies: 13Last Post: 01-10-2007, 12:36 AM -
Nitrogen purging?
By monkey spanners in forum Tools and CalculatorsReplies: 5Last Post: 10-06-2007, 09:47 PM -
Nitrogen freezer
By Peter_1 in forum IndustrialReplies: 11Last Post: 05-10-2005, 05:04 PM
