Thread: wine
    Nov 2006
    gozo
    13
    wine
    hi guys
    I have a client that has requested me to build him a refrigerating system where he can slow down the fermentation of wine. He already has a 77 litre tank and would like to keep the wine fermenting at around 15 degrees celcius... Any hints guys
    regards
    steve
    Re: wine
    A cooling coil wrapped around the tank perhaps ?
    ding dong's Avatar
    ding dong Guest
    Re: wine
    hi
    the way too cool a tank for wine is with a chiler
    ana a tank with double jacket .
    Aug 2007
    Adelaide Australia
    70
    562
    Re: wine
    As this is only 77 litres it's a pretty small tank. You could get a small stainless steel coil made that can be put in the tank and match it with a small condensing unit. The problem with a coil on the outside is getting good contact with the tank.
    Whatever way you go insulate the tank.
    Paul
    Sep 2006
    Venezuela
    259
    Re: wine
    The best way to control the temperature and also the wine quality is using chill water.
    I do not have any information of the material of the tank and shape.
    I will use a tank to chill water and with a small pump recirculate water throught a coil in the wine tank
    Mar 2005
    New Zealand
    43
    64
    Re: wine
    You could pass the wine through a heat exchanger, only risk with this is contamination of the wine if the heat exchanger ruptures but at 15 dgrees you should be ok, just make sure safetys are checked regularly.
  1. Cold storage system for bottled wine
    By Cewek ITS in forum Fundamentals
    Last Post: 13-11-2008, 04:39 AM
  2. Wine Cellar
    By mick5 in forum Air Conditioning
    Last Post: 12-09-2006, 12:53 PM
  3. Marine Wine Fridges
    By Globe76 in forum Trouble Shooting
    Last Post: 05-05-2006, 07:30 PM
  4. Wine Chiller Help
    By kris_problem in forum Domestic
    Last Post: 30-04-2006, 12:45 PM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
