    Dec 2008
    South Wales
    61
    Samsung RL33SBSW Problem
    Hi Guys and Girls,
    I've got a problem with my fridge/freezer in that it just locks out, i.e. the indicator neons at the top front stay lit, but the evap fan is at a standstill and the compressor is off...It happily restarts if I switch it off and on at the mains only to lock out again several hours later. I suspect its something to do with the defrost cycle i.e. not terminating the defrost at the evaporator probe, but surely there is a max' time out.
    I normally work on supermarket equipment so forgive my ignorance, would anyone know if the Samsung sensors types are PTC, NTC etc...
    Any help or suggestions gratefully received.
    Cheers RNINE
    Jul 2006
    norfolk
    737
    Re: Samsung RL33SBSW Problem
    airkool@hotmail.co.uk
    will email u all tech u need
    Jan 2009
    Yep defrost cycle it is, first check the thermal fuse, then the heater.
    Jan 2009
    brum
    aha - I have exactly the same problem !!
    where is the thermal fuse ??
    and what reading should the heaters be roughly ? (one I measured was about 10k which is seeming quite wrong now I think about it)
    many thanks
    O.
  1. Possible Samsung Problem
    By airefresco in forum Air Conditioning
    Last Post: 28-07-2008, 07:50 PM
