    Aug 2004
    744
    Can anyone offer advice?
    Hello chaps,
    I'm currently pricing a job for an existing client. I have done a heat calc and got to appx 100kw total cooling required. The area is one big open space. So far so good............I have calculated the VRF price and i have calculated the price for Splits, just as an excercise i want to offer a price for a chiller system as an alternative, what with all this F gas malarky.
    Where do i start? I have installed many over the years, but i have never specified or designed one.
    Cheers for any help or info
    eggs
    Jun 2001
    N.Ireland
    1,630
    Re: Can anyone offer advice?
    Quote Originally Posted by eggs View Post
    Hello chaps,
    eggs
    Hello Eggs,
    I suppose the place to start is the room conditions required, temperature and humidity.
    Also are you going to use fan coil units or an central AHU to distribute the air.
    There is another couplke of alternatives to chilled water that will work more efficiently, condensing units and an AHU or a number of rooftop units (combined AHU and Condensing Unit).
    Kind Regards Andy
    Aug 2004
    744
    Hello Andy.
    My chosen route, due to low(ish) ceiling heights and not much void, is cassettes.
    The application is just general comfort cooling for a retail area, about 950m2.
    Eggs
    Jun 2001
    N.Ireland
    1,630
    Hello Andy.
    Eggs
    Hello Eggs,
    most chiller manufacturers make fan coil units, that are to all purposes 4 way cassettes, but fed with chilled or heated water.
    They also make mini AHU's, vertical for mounting in the store room wall, returning air at low level and supplying it at high level.
    some manufactures are
    Rhoss
    Clivet
    Climveneta
    Aermec
    The chillers will have selection tables that relate to the chilled water onto and off the cassettes.
    All these manufacturers will assist you with selecting their product (or point you to an agent).
    Kind Regards Andy
    Jul 2007
    Hi Eggs,
    Can't really help you with the chillers, but you may want to consider another alternative, the Hitachi IVX system. Three outdoor units and nine indoor cassettes to give you 100kW will cost you around £16.5K. With only three refrigeration circuits to install it's got to be a good commercial option.
    May 2006
    Norwich
    134
    Not knowing hte full layout / Windows, and sun light.
    The most cost effective way would be 4x Multis. at 25 K.W each.
    You could zone the area into 4 zones if nessesary.
    Carfull if the ceiling is low, as the Mitsi Heavy are a draft nightmare.
    If the ceilings are low i would go for the Daikin roundflows every time, happy customers
    Feb 2008
    Sudan
    89
    Hello chaps,
    eggs
    Hi eggs,
    I will give some questions may help you:
    - What is the application of your space?(Resturant, meeing room, ......)
    - What is your ventilation requirments?(fresh air quantity)
    - What is your options for the external units location?(air cooled-outside- , water cooled-inside-)study your building to deside.
    - What is your control needs? (High control-on/off...)
    - Are you need heating beside cooling or just cooling?
    These quistions may help you to select the suitable system.
    Aug 2004
    744
    Thanks to all for the replies so far, but i do feel we are going a little off topic.
    I am more than happy specifying VRV, VRF & Splits. I have done a full accurate heat calc including allowing for the ventilation rates that i have designed my ductwork system to do.
    I am just interested in how to design and specify a chiller system (to broaden my knowledge more than anything else). 100kw chiller to 9 cassettes.
    Ie:
    Step 1, Buy Chiller
    Step 2, Buy 9 Fan coils
    Step 3, Oh $hi7 !, what's all this about pumps and flow rates. Ahhhh! metering devices, 4 port valves, auto bleeders, Pressurisation vessels.
    Thankfully, i have a quiet day on wednesday so i'm going to ring a few of the companies Andy mentioned and try not to sound too amateurish
    Cheers Chaps
    Eggs
    Nov 2007
    London
    461
    One big open space, i would use 4 x RZQ250C and this will give you 100kw
    Nov 2007
    London
    461
    or the new Daikin cmsq.
    Aug 2004
    744
    As it happens, the job got put on the backburner.
    Quote "until all this credit thingies over with", thanks Mr Client.
    That is 3 jobs now been put on hold in the last 2 weeks, £120k gone as if it never existed.
    Eggs
  1. Advice needed for a friend
    By marc5180 in forum Training
    Last Post: 10-06-2009, 10:56 PM
  2. Seeking Advice on Retraining for AC&R
    By Stu76 in forum Training
    Last Post: 23-08-2008, 10:52 AM
  3. advice needed on carrying refrigerant cylinders
    By maidy1 in forum Air Conditioning
    Last Post: 18-05-2008, 07:29 PM
  4. Career advice please.
    By james 100 in forum Chit Chat & Service Stories
    Last Post: 13-09-2007, 06:37 PM
  5. Hello To everyone need some advice
    By Andy2no in forum Domestic
    Last Post: 24-07-2006, 12:14 AM
