Thread: trane
11-11-2008, 08:41 AM #1
trane
hi guys
just after some information on trane cgadd series chiller. (old recip)
it has been going out on hrd-5 fault, which is a problem with the rcm module. i changed rcm modules with spae i had and it ran for a few days then it faulted again and when it powers down it resets its own fault.
so i spoke to some guys at work and they said it was from a eprom fault meaning a sensor/ solonoid / probe causing problem so i replaced a suspect solonoid and it worked for 24 hours it has now gone down again any help greatly appreciated.
13-11-2008, 08:30 PM #2
Re: trane
check the grounds of the RCM! If that fails place a "magnet" (don't know the correct word in Engish) around the sensorwires near the RCM to reduce induction picked by by the wires.
Also check all solderings on the back side of the RCM and the flatcable, if present, between the main module and secomd one!
15-11-2008, 05:48 AM #3
Re: trane
thanks for your help i will try the magnet trick
Trane heat strip
By SLB in forum New to REReplies: 4Last Post: 16-10-2008, 01:16 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM -
Trane unit not working
By lh12345 in forum Air ConditioningReplies: 9Last Post: 11-09-2008, 03:22 AM -
Trane Defrost Control Board Energize "W" in cooling
By jcmorris2 in forum Heat PumpsReplies: 6Last Post: 02-06-2007, 03:40 AM -
Similarities (differences) McQUAY vs. TRANE
By Jacek in forum Air ConditioningReplies: 3Last Post: 01-04-2007, 09:46 PM
