    Backhertz's Avatar
    Backhertz Guest
    Geothermal Closed Loop Question
    I have a 3-ton Climatemaster closed-loop geothermal system with two 300 foot wells.
    I was in the process of having Sonotube footers dug & in the process, one of my well pipes was severely nicked by a shovel. So I opted to have it repaired. My well guy cut out a 2-foot section and heat fused it in place. The system was purged and topped off & works well.
    My concerns is we noted the color of the antifreeze had a dark hue & wasn't blue like it was when the system was filled back in April. I also noticed the inside of the piece of pipe we cut out has what looks to be a rust film. I'm not sure where the rust is coming from. Anyone have any idea(s)? I contacted the well guy. He used water that was process through an ion exchange unit & had a ph of 7.5. He said an additive could be added, but is it necessary in a closed loop system where Charter Plastics geothermal pipe 3408-C-3-
    dr-11 was used?
    Jun 2006
    British West Indies
    543
    Re: Geothermal Closed Loop Question
    are you on well water, the film could have been iron in the system, it could also be bacteria
    maybe the iron is coming from a grundfos pump or another ferrous element in your system
    Take the V out of HVAC and you are left with a HAC job
    Feb 2007
    France now, Suffolk before
    55
    294
    Abby, I don't understand what you mean by the iron coming from a grundfoss pump, could you elaborate.
    Expat, remember Grundfos pumps come in lots of different sizes/materials.
    Jun 2006
    British West Indies
    543
    Quote Originally Posted by expat View Post
    When you use the small circulators on an open system, they are usually made with bronze or stainless.
    The OP is using high density PE pipe, it is a closed system, but could still be a little prone to oxygen diffusion. If the pump is ferrous you could get some rust.
    Apr 2002
    scotland
    114
    the monoethylenglycol will just eat away at any ferrous metals in the system, this could be the pump itself or any mild steel fittings.
    You prob already know this so if it was me I'd be having a look at the pump as abby says and check to see what it is made from
  1. Refriferation cycle question
    By ozmecheng in forum Fundamentals
    Last Post: 26-03-2008, 10:38 PM
  2. Hitachi RAC25NH5 question
    By Yonas in forum Heat Pumps
    Last Post: 30-01-2008, 10:53 AM
  3. Newbie with a question
    By AcidSlasher in forum Fundamentals
    Last Post: 07-03-2006, 11:20 AM
  4. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
  5. closed loop chiller
    By bender in forum Trouble Shooting
    Last Post: 02-01-2003, 01:32 PM
