Results 1 to 29 of 29
Thread: Deep vacum problems
20-10-2008, 09:56 AM #1
Re: Deep vacum problems
Then send it back with a giant "FAIL" stamp on the box!
Adding a heater is negating the whole concept of the goal of sub cooling the refrigerant and rejecting heat from it! might as well choke off the condensor rather then add a heater, same effect!
If it is freezing up there is an fundimental issue with the unit or the design of the unit that must be rectified properly! Does it take more work and thought and time? Yes but once resolved it is truely fixed, and equipment life will be better for it and the quality of repair superior!
In the time of low cost garbage, incompitant & half assed repairs (due to under-trained & overloaded techs) and throw away products, taking some time to do a therough and solid repair doesn't go un-noticed
Just some personal thoughts and observations.
Carrier 30XA Liquid chiller Problems
By Ed Burris in forum CommercialReplies: 7Last Post: 13-08-2010, 08:12 PM -
samsung rs21dcns problems
By slovenian ian in forum Trouble ShootingReplies: 2Last Post: 03-11-2007, 03:19 AM -
Oversized Liquid Recievers?? Problems??
By nickjh in forum FundamentalsReplies: 12Last Post: 12-06-2007, 07:54 AM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM
