    May 2008
    13
    Question New Refrigerant with old evaporator
    Joe consumer here. If I replace a 20+ year old R-22 home AC condenser with one with current new refrigerants will I have to replace the evaporator (only 2 years old) in the furnace? What is the most common refrigerant used in new home AC systems?
    Feb 2007
    2,473
    Re: New Refrigerant with old evaporator
    Probably but your best option is to ask the manufacturer.
    May 2008
    66
    802
    if the outdoor unit is not broken, why not clean the tubes en switch to R290 ? it is the best replacement for R22. just be careful, its flameble gaz.
    grtz, Ice
    May 2008
    66
    802
    O yeah,
    here in Belgium the newest is R410a ,
    grtz , Ice
    salman ahmed's Avatar
    salman ahmed Guest
    I have a problem of refrigeration system of cold store problem is, i want set temp -20 but system not reach that point. sight glass showing system under charge if i increase gas R404a discharge pressure too high above 350psi, please suggest what i do
    Apr 2006
    1,620
    Quote Originally Posted by salman ahmed View Post
    I kindly suggest you do not break into another fellows thread, then make a new post of your issue with more detailed info. I will all so suggest you put it into the proper forum!
  1. Superheat and Subcooling
  2. Replies: 16
    Last Post: 20-02-2008, 11:15 AM
  3. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  4. Refrigerant jumping evaporator
    By Cary in forum Trouble Shooting
    Last Post: 30-07-2007, 11:17 PM
  5. Replies: 3
    Last Post: 06-11-2006, 05:04 AM
