17-09-2008, 08:18 PM #1
Cooling and dehumidifing by chill water
AS it shall be known , one of the first HVAC system was done spraying cool water in a air current .
Of course the water temp was below the air dew point , so the air water was condensated on the sprayed water drops.
My need is where to reffer to make some calcs about it.
Thanks in advance
17-09-2008, 09:49 PM #2
Re: Cooling and dehumidifing by chill water
that is what's cold "adiabatic cooling" .is something wat is still being used on RV systems.they are the cheapest and also works whit 12V motors.
Ice
17-09-2008, 09:53 PM #3
the system in RV's is spraying normal water on a quick turning disk, that sprays the moisture around. you have to use a Mollier diagram for adiabatic cooling.
Ice
17-09-2008, 11:21 PM #4
It is not a evaporative cooling , it leaves the air alsmost saturated in water .
My case is an AIR WASHER dehumidifing .
18-09-2008, 01:35 AM #5
I repeat , it is about DEHUMIDIFICATION , OR AIR DRYING.
22-09-2008, 07:07 AM #6
Frick has a calculation data on this. I shall see if we have the copy of that. That is an interesting article for sure.
I did not see any one else has worked on that. ofcourse Frick is now part of York, but I think those details must be still available
22-09-2008, 10:18 AM #7
is it something like this, but much bigger. it cleans, wasches regulates the moister of the air ???
http://www.rainbowsystem.com/rainbowsystem/history/
Ice
22-09-2008, 10:20 AM #8
i now a guy ho doing that at a car plant. its being used where the paint the cars.
Ice
26-09-2008, 02:58 PM #9
