Thread: Triple vac
17-09-2008, 11:46 AM #1
Triple vac
When using the triple vac method, in the process of breaking the vacuum with dry nitrogen what is the presure required. I assume and use 0 guage, can someone assure me this is correct?
17-09-2008, 12:16 PM #2
Re: Triple vac
Yes, 0barg is fine
Tony
17-09-2008, 07:58 PM #3
Re: Triple vac
Breaking the vacuum with nitrogen, preferably with a dew point of minus 50 degrees or lower, is as we all know for speeding up getting a moisture free system. Breaking to a pressure, more than 200 mbar (eff), is useless because the work of absorbing present moisture is already achieved for 100% at this pressure.
Triple evacuation
By kpapa in forum FundamentalsReplies: 32Last Post: 22-02-2010, 10:35 PM
