Thread: ice maker stuck on crush
09-09-2008, 11:31 AM #1
my l g fridge freezer is stuck on crushed ice setting and i cannot alter fridge temperature
09-09-2008, 10:34 PM #2
Re: ice maker stuck on crush
Check that you haven't accidentally activated "child-lock" on control panel (refer to intructions). Failing that, try turning off at mains, wait 10 mins or so and re-start. Not a definitive answer, but may help
10-09-2008, 12:07 AM #3
As an authorized servicer, the most common problem with LG refrigerators is the control boards, try unplugging it then check the wiring connections under the top left door hinge cap and at the Main PCB in the rear of the refrigerator.
Amana refrigerator/ice maker problem
By SCStewart in forum Trouble ShootingReplies: 6Last Post: 08-08-2010, 10:50 PM -
Ice Maker (Nice Ice) Faulty: Help!
By ArthurLeigh in forum CommercialReplies: 4Last Post: 25-10-2008, 10:49 AM -
Flake type ice maker
By vinod in forum Technical DiscussionsReplies: 0Last Post: 25-04-2008, 08:26 AM -
Derating factor for ice maker using salty water
By Gonzalo Arias in forum NH3Replies: 1Last Post: 18-05-2007, 03:57 PM -
Scotsman Dc33pa Ice Maker Troubleshooting
By Sean LaDart in forum Trouble ShootingReplies: 8Last Post: 13-02-2006, 08:01 PM
