Thread: Design Pressure
03-09-2008, 03:24 PM #1
Design Pressure
Hello All
What is the design pressure on a data tag of a reach-in cooler referring to? Is it what that system is designed to run at, the max pressure it can safely run at, the max pressure the system can handle before the solder joints burst?
03-09-2008, 07:55 PM #2
Re: Design Pressure
The design pressure is probably the safe test pressure that can be applied to the system.
03-09-2008, 11:47 PM #3
Re: Design Pressure
mdnorthrup,
Check out these two links. They contain good information on design pressures.
Tecumseh: #ER-15
http://www.hvacrinfo.com/tech_ae_index.htm
Copeland: Section 25, # 25-1177
http://www.hvacrinfo.com/ae_index.htm
How to Design Refrigeration Systems
By US Iceman in forum FundamentalsReplies: 63Last Post: 24-07-2008, 04:27 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
