Results 1 to 1 of 1
Thread: Bohn Chiller w/ screw compressor
14-08-2008, 12:16 AM #1
Hi Guys,
I am squared away in residential and light commercial but am venturing into new territory with a screw compressor. About a month ago I had to make a coil repair to this chiller due to a fan that broke and damaged the coil. This unit is about 20 yrs. old with a 55 ton Dunham-Bush compressor. Made repair and all necessary procedures to bring back on line. Unit came back up with no issues. Went back about a week later to remove high water drier cores and replaced with regular cores. Again back on line with no problems. Call today from them with complaint of minimal cooling. Found pressures 100 suction and 215 head. Loading solenoid energized. Electrically everything seems to be working. Reset power and watched as unit started up, fans on, solenoid snaps but no change in pressures. My thoughts range from a possible malfunctioning TXV to perhaps in spite of the electrical solenoid working that the loader itself may not be. Any help would be great.
Thanks, Tim
advantage of twin screw compressor over single screw compressor
By azzah in forum New to REReplies: 7Last Post: 23-09-2008, 09:24 AM -
Autoloading slide valve for Screw compressor
By screw_geek in forum Industrial CompressorsReplies: 32Last Post: 04-04-2008, 03:47 AM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Screw compressor vibration
By jpumarada in forum Industrial CompressorsReplies: 14Last Post: 26-04-2006, 01:43 PM -
screw compressor failure
By aygul in forum Trouble ShootingReplies: 23Last Post: 09-12-2004, 09:09 AM
