    Superbee's Avatar
    Superbee Guest
    Refrigerator Help
    Was work Perfect for a year and then one day water every where from the freezer ICE melted it was 60 in it
    I unpluged it and 10 min pluged it back in Cleaned it up in the back alot of dust, Worked perfect like nothin was wrong that was 3 weeks ago Today same thing the ICE started melting water every where Flood.
    Any Ideas? i didn't see that it was freezing up anywhere like low on *****, what i think is the defrost might be staying on, but i don't know anything about Refrigerators
    Any Help would be great
    it's a
    Frigidaire
    Model# FRS26R4CW1
    Year 02-04
    Vern
    Superbee's Avatar
    Superbee Guest
    Re: Refrigerator Help
    Thanks for all the HELP!
    Jul 2006
    norfolk
    737
    Hi, sorry only have uk listed models so cant help much but sounds like could be fault with drain hole make sure nothin is blocking it
    Apr 2006
    1,620
    Agreed, check to ensure the drain is free flowing and it has some where to go.
    Sounds like the defrost is doing its job and all.
