Results 1 to 36 of 36
Threaded View
22-05-2008, 11:40 PM #10
Re: Just cleaned my built-in fridge's condenser coil - now the compressor won't start
Cutting the old tube is not a problem but be prepared for a nasty smell.
You never know which refrigerant they have charged the 'stat phial with.
Once you've unplugged the wires try giving the cap line a steady pull, sometimes the things will pull out.
If possible put the new one back where the old one came from.Brian - Newton Abbot, Devon, UK
Evaporative Condenser in reverse cycle
By Friobernal in forum IndustrialReplies: 6Last Post: 16-04-2009, 02:06 PM -
How does an inverter fan coil communicate with its condenser?
By kevin090972 in forum Heat PumpsReplies: 11Last Post: 22-07-2007, 10:38 AM -
Condenser Coil Positioning
By marks in forum FundamentalsReplies: 3Last Post: 02-07-2007, 03:03 AM -
Condenser coil cleaners
By chillyblue in forum Air ConditioningReplies: 4Last Post: 02-06-2007, 01:26 PM -
High pressure reading before and after condenser coil
By Cofreth in forum RefrigerantsReplies: 6Last Post: 18-11-2005, 04:30 PM
