Results 1 to 31 of 31
Thread: Can someone point what's wrong
Threaded View
08-12-2003, 09:15 PM #8
Hi Daliti
well put it another way I would consider switching the neutral or common as poor practice, which will eventually see the culprit come un-stuck or some poor sod comming after him. Me I don't switch commons/neutrals, the same as I don't purge air from fridge systems, others can do as they see fit
You could also be having a partial suply voltage from the coil of the eliwell controllers, dependant on what internal protection they have to prevent this.
Safer wire in a relay or contactor to drop the suply voltage to the solinoides (tru a n/c contact)
Kind Regards. Andy
Whats wrong here then ???
By cool it in forum Chit Chat & Service StoriesReplies: 11Last Post: 09-10-2005, 12:22 PM -
Whats gone wrong!!!!!
By jbear in forum TransportReplies: 2Last Post: 14-03-2005, 12:17 AM -
Low Temp Low RH Room
By David PS in forum Technical SpeculationsReplies: 9Last Post: 07-05-2003, 04:30 AM -
superheat with the wrong orifice
By superheat in forum Air ConditioningReplies: 9Last Post: 25-10-2002, 08:54 PM
